Hi all, I’d prefer to post after I’ve investigated an issue, but I currently have some time on my hands so here I am!
During some moderate off-roading, (not sure if it is the cause, just happened then) my engine started having intense vibrations most noticeable at 2,300 RPM.
It is noticeable at idle when the engine is cold but not when it is fully warmed up.
It is more intense in first and second gear but noticeable in all gears.
It sounds like a knocking noise, will link a video when I have better service.
Additionally, when I start the car there’s a knocking sound right when the engine “catches” or starts.
No check engine lights
Sounds like it’s more on the drivers side of the engine bay but I’m not sure.
From asking people I know (with varying levels of experience) I’ve heard it’s possibly the
Once I get above 3,000 RPM it runs a lot more smoothly and there isn’t a noticeable lack of power anywhere in the RPM range.
Any ideas would be greatly appreciated
- loose harmonic balancer
- knock sensor
- cylinder misfire/compression issue
- EGR stuff
