Baloney.He said that engines using timing chains produce more engine noise than those with timing belts.
I can't speak for Toyota specifically but as a general statement it's not true.
This is a design flaw in the VVTI engine. I am just realizing this now after buying a used RAV4. Been learning a lot about this and another design flaw with the transmission when the overdrive kicks in. I get this shudder at 40-50 mph and when between 1600-2000 rpm.So how long would you like Toyota to cover your car? 5 years? 10 years? Forever? ALL manufacturers have warranty periods for a reason. Nothing can be garunteed to last forever, after a certain period of time, it HAS to become the responsibility of the owner.
Hey I fixed the tranny shudder temporarily by changing some of the tranny oil. I probably only got 3-4 quarts changed in the time I had but it was enough to get rid of the shudder. I noticed the other day that it might be returning. Probably put 10k on it since.. I also have the start up clatter! Especially nice is the charcoal canister test failure which disables all-wheel-drive, cruise, traction control in the winter time only it seems! I have a 2011 Toyota RAV4 with the 2.5l engine, 135k miles.This is a design flaw in the VVTI engine. I am just realizing this now after buying a used RAV4. Been learning a lot about this and another design flaw with the transmission when the overdrive kicks in. I get this shudder at 40-50 mph and when between 1600-2000 rpm.
