I’m working on an ‘08 RAV4 and I’m getting the following two codes:
P0101 Mass or Volume Air Flow Sensor "A"
Circuit Range/Performance
P0171 System Too Lean Bank 1
The car cranks but just won’t start. To date, I’ve done all of the following and haven’t gotten any results.
•replaced spark plugs
•swapped coil packs with known working ones
•replaced pcv valve
•clean and also swapped in known working MAF sensor
•reassembled and visually inspected air intake and hoses
•cleaned throttle body
•starter turns crank pulley
•battery voltage ~12.25
•half tank of gas left
•Did a spark test with the coil and 🪛 and got an Amber colored spark
•Tested fuses for continuity. Visually checked larger fuses.
•O2 sensor shouldn’t keep the car from firing up. I unplugged my personal ‘08 rav4 and was able to start it up
•sprayed starting fluid into intake tract and doesn’t even attempt to fire
I’m stumped at this point. Is there anything else that you guys can recommend I check? TIA
•replaced pcv valve
