New to this forum, and our 2013 Rav4 Limited. Member in the TacomaWorld site. Having a problem exiting the screens after doing the General, Vehicle, and other basic system configuration setups. I want to fet back to the screen that appears after startup. The only way I've found so far to exit is to shut the car off then back on again. There's got to be an easier way while driving. Any words of wisdom? Thanks for your input.
G
Depends on which radio you have.. I have the Entune w/nav. To get out of the setup screen, I just hit Audio, or Apps, depending on what I want to do next. If you hit the center button on the steering wheel, I think they all default to the Audio.
And there should be a virtual back button at the top right corner of the screen to back your way out. I also just push the physical audio button as bill does.
