1 - 11 of 11 Posts
Hi everyone! I'm new to this forum, glad to see there's a website for others who love ravs. I recently purchased a 97 as my first car. I'm 6'4'', which is pretty tall for a guy, and I want to see if I can make a little more leg room for me. I was thinking maybe creating a longer seat track by welding an additional piece in the back. I also know there's a website specifically to add leg room, but of course, they don't make it for the 1st gen... Any ideas? :D
I had a small car when stationed in Japan and I just unbolted the seat, drilled new bolt holes, used new nuts with large fender washers from under the car and rebolted the seat down. Have to look how the RAV4 seat is bolted in and the shape of the floorboard.
Be sure to seal up the original holes to prevent water (and fumes) from getting in!
That's great idea eodgator, but how would I plug up the holes? Also, what did you use to drill the holes?
Hey Muppetseb,
Parts needed:
1) 4 each appropriately sized grade 8 nuts
2) 4 each appropriately sized large and thick fender washers
3) 1 each cross member similar to the one the front of the seat is bolted into - this was added after it was pointed out that the seat is bolted to a cross member only at the front. The rear of the seat is just bolted into a reinforced area of the floor. The cross member would have to be secured to keep the front of the seat rails at the appropriate height as well. The cross member may have to be welded in.
Tools needed:
1) Hammer
2) Punch
3) Drill
4) Appropriately sized drill bit
5) Appropriately sized wrench
6) Appropriately sized socket
7) Ratchet
Procedures:
1) Look under the RAV4 and make sure you're not going to drill into anything like brake lines, gas lines, wire bundles, exhaust system, etc. Caution: Under the driver's seat in a RAV4 are brake and gas lines
2) Unbolt the seat and pull the carpet back so it cannot get in the way and muck up the drill bit
3) Put the seat where you want it and mark the spots to drill.
4) Use a punch to indent the drill locations so that the drill bit doesn't walk
5) Drill the holes
6) Place the seat into place and check the position, remove seat once confirmed
7) Seal the old bolt holes with a copious amount of marine silicon caulk
8) Replace the carpet and cut holes for the new bolt locations
9) Replace seat and bolt it in...
Happy camper time, you can drive the car without your knees on the steering wheel!
Just an afterthought, plug up the holes with some seat bolts from a junk yard.
That description was way too simplified. The seat doesn't bolt to the floor. It bolts to a raised crossmember at the front. With some good engineering you should be able to move the seat back further.
It doesn't appear safe to simply drill new holes into the RAV's floor since the existing holes are clearly reinforced for safety and structural reasons. It would seem that one could weld or bolt new mounting brackets , maybe cut from seating rails obtained from an auto salvage yard, onto the bottom of existing seat mount rails, at the needed points to move the seat back, and use the existing floor mounting holes. That would raise the seat height marginally, which would be beneficial unless the driver is quite tall.
If you look at my first post it said that you have to look at how the seat is bolted in. My RAV4 isn't with me at the moment so I cannot go out and look. If there is a frame member that the seat is bolted to then you must provide a similar strong point. It would be the same if you upgraded your seats and installed seat rails that didn't exactly match the RAV4s bolt in points.
I edited my instructions to address the cross member at the front of the seat. I wouldn't want someone to try moving the seat without addressing this issue.
I would like to have better seats in my Rav4, but these seats have a weird mounting and I don't what else might fit.
But it is nice how far they slide to the front.:smile
Corbeau Baja XRS
This link is for a Corbeau Baja XRS Seat (which is on my short list of upgrades) and specialized seat brackets.
Seat: Corbeau Baja XRS Suspension Seat|Pair Ships Free!
Custom Bracket (just choose the RAV4): http://www.racing-seats-usa.com/corbeau-custom-seat-brackets-vehicle-specific-bolt-in.html
It is a suspension seat and has lumbar support and seat heater options.
1 - 11 of 11 Posts
