At 41" leg room on the RAV4, tall people like me, may find it less than desirable. Even my Subaru Impreza has 43" leg room.
I could not find any seat extenders to fit the RAV4 so set out to find a solution.
To extend the seat backwards, I used three parts:
First are universal seat extenders from YearOne: Single Part Search Result For sb246
Second are seat spacers to raise the seat above the bolt heads: Amazon.com: Timilge 0.25" to 1.5" Adjustable Front Seat Spacer Lift Kit(Rear of Front Seat Recline Kit) for Tacoma 4Runner FJ and GX : Automotive
Finally some grade 8 bolts 5/16 - 24 about 1" to 1.25" long. The bolts that come with the YearOne extenders are smaller and weaker than grade 8.
Installation: Since the holes in the YearOne extenders are smaller than the mounting bolt in the RAV4, drill out the front hole to fit. The hole closest to the front will give 2" extension. The second hole will give 1.5" extension.
Then drill and tap the rear hole in the extenders for the 5/16 - 24 bolts. Since the extenders are soft steel, you may want to use 5/16 - 24 nuts, grade 8, on the bottom for extra strength.
Mount the extenders using the factory seat mount bolts to the body captive nuts. Then mount the seat to the extenders using a spacer between the extenders and the seat frame so when the seat slides forward, it will clear the factory bolt heads.
Front mount:
Rear mount:
Side view of front mount showing spacer:
Front mount:
Rear mount:
