1 - 16 of 16 Posts
Have you done something inside also? I wouldn't mind any mild footwell lighting for example
Discussion Starter · #7 · (Edited)
Where did you tie in the power "red" wire to? and where did you ground it.
HI Ravvy17,
I spliced the LED puddle lights to the outter door sill protector LED lights,
which I installed using scotchloks/tapsplice from home depot:
Gardner Bender Tap Splice Assortment - 22-10 AWG - Terminal and Connector Kits and Assortments - (10 per clam)-15-2210 - The Home Depot
To see where I tied in the power "red" and "ground" please see these threads:
http://www.rav4world.com/forums/109...8018-need-pinouts-16-hybrid-limited-help.html
http://www.rav4world.com/forums/109...led-door-sill-installed-corrected-pinout.html
Both the outer door sill LEDs and Puddle LED lights fade on/fade off when any door is opened/closed,
as well as when the alarm is disarmed/unlocked.
This would be mine. Realistic? Of course not but desirable.
Discussion Starter · #11 ·
The blue interior lights were great, until suddenly the wife had to read something at night. I decided to put all white up front and blue in the rear since it is only both of us so not expecting any other readers anytime soon:rolleyes:
Does anyone know how difficult it'd be to take the glossy black trim for the lift gate on the SE and put it on the hybrid? I kind of wish Toyota did that for all trims.
Sent from my XT1585 using Tapatalk
HI Ravvy17,
Looks pretty simple. You just tied in the power and ground into the correct wire using the connectors I assume is what I can tell from the other posts.
1 - 16 of 16 Posts
