P
Fifth gear and fuse issues.
I just picked up a 1998 RAV4 four door five speed. It has started to pop out of fifth gear. I understand it's a common problem. ANyone know the cost of getting it fixed, in Canada would be best but a US quote should be similar. Also, all of the power windows and locks have stopped working. I figure that must be a fuse or relay issue but the manual doesn't tell me where the fuses or relays for power windos are located. ANyone know?
Thnaks
PJ
F
Discussion Starter #2
I just got a quote from Spinelli in Pointe-Claire Quebec. They want $1061 for parts plus 5 x $73 hrs labor.
I got a verbal quick-quote from Eastern Transmission ~$600 parts and labor.
In any case, I plan to take Toyota to small claims court because this is clearly a design or production flaw.
The repair of fifth gear has cost us , in January 2004, 727,25$ CND.
More applicable taxes (GST and TVQ... in Québec)
Details:
Parts:
33393-12022 hub clutch 126.70$
33395-12021 sleeve 114.80$
33336-12061 fifth gear pinon 159.30$
90364-28023 roller 35.60$
33151-28020 roller stopper 107.60$
Oil: 15.75$
Total of parts: 559.75$
Labour: 2.5 hours at 67,00$/hour
Total labour: 167.50$
It's possible to do this job without removing the transmission from the vehicule!!!
My dealer did that!
About fuses boxes, one is located beside the hood opening lever and two are located just beside the air filter box.
EDIT: Farker: Look at your private message!!!
P
Thank you both for the info. Joel, I will take your parts list to a transmission shop here. I'll see what the quote is based on your information. I do like the Rav, very dissappointed that these things happened within a month of buying it though.
