G
h&r springs only drop about 1.5 inches, so i had to cut, final drop front about 3.5 rear 3.8, i cut the h&r springs in order to achieve the drop, if the shocks blow, no big deal im goin to go with air bag suspension
G
Discussion Starter #2
How does it feels? I heard that when you cut the springs, the ride feels like a toad, very jumpy ride.
And did you cut it yourself?
G
i cut my h&r springs so they were progressive springs and my shocks are brand new, so my ride is not bad at all. My shop here did all my work (i am a salesman at an accesory shop in miami)
G
ooh ok cool! so you recomend to take it to a shop. How much you think is the reasonable to pay for all that? To see if I can afford it.
G
h&r springs will run u $240 labor for cuttin and installin the springs = $100-$150 bones
3.5 and 3.8 inches?...wow, that's insane. You doin' okay with your ride shorty? We've had some heat before discussing other topics. Even with my 1.5" drop with the H&R's the alignment was way out of wack. The alignment diagram i got from my shop is on cardomain.com It shows before and after photos: http://www.cardomain.com/ride/351327/20
Basically pink means bad, and blue means good. There was tons of pink. Even after a camber kit the alignment isn't exactly to specs. 3.5 would definitely wear out your tires big time. H&R's also weren't meant for such an extreme drop. Careful you dont' bottom out...especially with those stock struts/shocks you have. Just trying to watch out for your safety and that car of yours.
