1 - 12 of 12 Posts
I am about to pull the trigger on getting some of these. I believe that the inner rear tire wear on my car is due to carrying load. The rear alignment toes out when the suspension sags. I might be taking a trip with 5 adults and gear for a couple of days and do not want to kill my tires.
I am searched and read almost every thread on this topic. My question where do people mount their air valves. One says he mounts them inside his gas door. Any other suggestions?
I run similar airbags on my truck and am well versed in their application. Just curious where a good place to mount the valves.
I installed mine in the floor compartment, with both sided connected together, then a pressure gauge with the fill valve after that, that way I always know how much pressure there is.
Reactions: MrPulldown
I have 3rd row seats that fit into the compartment. but I think there is extra space. I will look into it.
i think that I might tie the R/L together too. I found that on my truck this is a bad idea for 4 wheeling as the downhill side will experience sudden loss of spring rate.
Another question for those that have installed the bag. Etrailer shows this as the preferred routing for the air line. Seriously. Can I tuck the line inside the lower control arm, or does it need to make that gradual loop to avoid kinking. That line will get ripped off in no time.
on mine, I routed them down and to the rear tied with zip ties to the arm, not enough room to route them directly to the side.
Thanks. I would really like to tuck that hose in a safe location. Though I don't wheel the RAV very hard, there are plently of times when I am driving over brush or compacted snow (berms). Need it not to catch on anything.
I am receiving my bags today and will try to get them installed tonight. I will be heading up to Nakusp BC and will have 5 people and gear.
Another question how did you go route the hose into the cabin. Did you find a plug/grommet or did you drill a hole.
lots of snow and ice where I live, and didn't have any problems yet ;-)
there are a couple of grommets in the back of the trunk, I just used the one in the middle
bear with me but how do you know how much air pressure is necessary? Also do you adjust air pressure from towing / not? Also how bad is the install assuming i don't have a lift or more than a few jacks/jackstands. Is this a good solution to help improve towing? We have an extremely lightweight camper but at times it can start bouncing and almost make you sea sick if the road is bad.
I put 5psi when not loaded, and anywhere from 20 to 35psi when towing.
the hard part of the install is getting the bags in the springs, on one side I was able to slide it in, on the other I actually had to undo a suspension bolt to get more room.
what is the tongue weight of your trailer, if the weight is too light (<10% of trailer weight) it will bounce more easily.
Reactions: philliphair
1 - 12 of 12 Posts
