What makes you all so sure that the solder used in those ECMs is lead free? Because it is not. It looks like that because of the process used to assemble the unit. The resistors is just part of the problem, not the problem itself. Those are current sensing resistors, used to record the current amount passing to the solenoids and then populate the transmission adaptation table memory with proper codes for a better shifting. Resistance value is low (0.33 ohms) as to not significantly lower the current going to the solenoids, while sensing the voltage drop across the resistors to calculate the current draw at different times.
I see that there are still many "shops" on trial and error (playing) with these units. That is why we receive so many units poorly worked out and needing extra repair, specially coming from eBay.
Please guys, be careful who you buy a service from on eBay. Some units that many of those "shops" tried to repair are then sent to us by those customers in a second attempt to repair their ECMs.
Some units are left unrepairable as there are some of those "shops" that after doing their non-working job, they cover the circuit with some epoxy, leaving the unit impossible to be reworked without damaging the circuit board. I have seen others putting underrated parts, like a 25v capacitor, where the original is 50v. They must be saying, "well, it is a 12volt system, so a 25v capacitor will work". They do not even take in account the internal switching power supply of the ECM, that generates voltages higher than 25v. Some other put a lot of solder in the grounds, taking as true, the myth of the poor ground problem in the screws area. Summarizing, they are just playing to make an easy buck and won't refund a cent when it fails, giving the excuse that it must be the transmission. In some case, it is the transmission, but in the majority of the cases, it is only the ECM.
