OK, then look on the opposite side, behind the glove box. Pop off the little damper and you should be able to drop the glove box door all the way down.thanks for that but my Rav4 does not have a panel like the one shown to the right of my steering column. I have had the trim off down there but cannot see any relays:serious.
Hi, do the LED's work without resitors (only the relay) ?This photo shows the flasher relay in my 2008. The panel is to the left of the steering wheel, between the dimmer control and the bonnet release. I would assume yours is the same, but reversed for RHD:
Yes, with the electronic flasher unit there is no need for resistors.Hi, do the LED's work without resitors (only the relay) ?
I have a RAV4 2008 and planned to replace only the bulbs and relay.
Sure, you can get one from Amazon. This one fits the 2006-2012 RAV4:JUNEBUG - Can you provide a few more details on the digital flasher relay? I've got a 2016 Rav4 and have been searching (without success) for information on the location as well as recommended digital relays that will accomodate LED bulbs .... many thanks! Uncle Al
Nice but expensive. Some people don't even signal when turning.I replaced mine with this one from diode Dynamics. I have a 2007. It has programmable features, like double flash, strobe, slow, wig wag and more. https://www.diodedynamics.com/smarttap-led-flasher-for-2001-2012-toyota-rav4.html
Sent from my SM-N960U using Tapatalk
