B
Is there anywhere beside Toyota, that I can order the Fog lights/Turn signals? combination??
currently, I have just the Signal set-up
B
ya I took a look on ebay, they had some
I guess I have to do a separate search for the signal portion?
gets pretty pricey it seems once you get both pces :roll: :? :(
The eBay foglights are not OEM which means the switch is not located by the wiper/turn signals are.....you need to buy a separate switch and install them somewhere on your panel.....i will try to take a pic and post where I installed mine..... :lol:
if ever you go by this route i might be able to help you with locating the wires and how tap into them.....just PM me i'll do my best to provide pics. :)
B
thanks Boo_Duh!
I've noticed several blanks on the lower dashe on the drivers side.. perfect location for some switches!!! :)
I'm pretty experienced when it comes to wiring, but if' you've done this mod already.. I wouldn't mind knowing your method
I'll PM you when I pick up some fogs :cool:
