OK, the dust shields for the front rotors on my '02 Rav4 rusted through completely. From all the youtube videos I noticed that the only way to replace it would be to remove everything including the hub bearing out of the knuckle. Well, this is what I did this afternoon to replace them:
First I ordered mine from ToyotaPartsOverstock.com for $27 per shield.
The drivers side went with no problems. First I took out the whole caliper/rotor assembly out and rested on the bucket. The 4 little bolts that held the shield to the knuckle were rusted but I was able to unscrew them without any difficulties. These bolts were 10mm bolts with 6 point hex on top. 10mm socket took care of it without any problems.
On drivers side I was able to reuse these bolts to secure the new dust shield.
The shield itself had to be modify as I didn't wanna take out the whole hub assembly. I was able to cut out the slim side so than the dust shield could be slide onto the hub behind the bearing.
The passenger side was a different story. 2 out of the 4 bolts came out Ok, but the other 2 did not want to spin out. In the end I stripped out the 2 bolts and needed to think little harder. What I did, was using my Dremel with diamond wheel to cut/polish two opposite sides of each bolt to create flat surface on opposite sides of the bolt.. Then I was able to use 6mm wretchet to unbolt each bolt.
For the passenger side I used M6-1.0X12MM hex head cap screw with washers as the original screws weren't usable anymore.
End result is great as I probably will not have to do this again. The original lasted me 200,000 miles which I just did last Friday.
Hope this helps anyone who thinks of doing this but the idea of taking out the bearing/hub assembly scares them out of their mind.
I'm going to remember that trick you did with removing the bolt! thanks
No problem. Just make sure to polish each side in small steps. Polish and check multiple times with the smaller size wrench until it almost fits. When the wrench almost fits on to the polished bolt just slightly pound the wretch on to the bolt with hummer. This way it will fit snugly. Glad i can help
