Unfortunate event happened when I was taking turn in tight space and scratched across a pole.
Log story short, left with few scratches and a loose plastic trim.
Removed bumper clip and then fitt d with no use. Trim is still loose, you can see gap more in person than picture.
How can I fix it without removing whole bumper?? Or should I glue it in??
Worst possible case I am thinking is broken tabs. What do you think??
Looks like a broken tab,so it is not being held into the front parrt. $20 for a replacement piece on Ebay.
I think 52113-0R030 is the right part
Should I remove whole front bumper to fit this or removing clip retainer and bolt is enough?
No need to remove bumper, just clip retainer and bolt.Iinsert the tab from the new part into its corresponding slot towards the front, it should click into place, unless part of the old retainer broke off and is still in there, interfering with the tab on the new part, then just unclick that side of the bumper and the broken pieces can be removed.
