camshaft pulley holder . Toyota engineer are idiots. why not use holes in the
engine head or block and in the sprocket to align and lock easily the timing in TDC ? i had to spent few hours making yet another tool .
144244
I just used the old timing belt and alternator belt and vice grips to break the bolts free. And I used the old seal and pulled to drive the seals in. However, that crank seal installer looks nice!
Crank seal tool looks nice!
I am doing my whole timing belt/wp/seals right now actually, ended up using a $0.70 pvc pipe from Lowe's which worked perfectly. Had the crank seal out and in in about 10 minutes. Did the same for the cam seal.
That cam sprocket holder is also nice. I made one similar for this job too! It actually works for my cam sprocket and the crank pulley.
