anybody done this? have any tips?
I plan on getting the strut plus, strut with spring installed
my biggest worry is rust, vehicle has 246,000 miles on it
Not personally, but had them done last fall. It was about a $600 job out the door with my local guy. I want to say it was $300 in parts + labor. My car had about 130k and needed them BAD.
Just replaced mine on Friday, 2001, AWD. No big deal, but it helps to have an impact gun. Bottom bolts torque to 105 lb-ft. It also helps to have two jacks, one to raise the car, the other to support the wheel and line it up with the new strut when installing the bolts.
I did the change this past weekend, you don't need a impact gun if you apply rust penetrant and a long ratchet/breaker bar. I suggest putting the penetrant on at least a day before you do it, and then squirt a little on every 1/2 turn at first. Also, the stabilizer bar that attaches is going to be a bear since it uses a hex, it was obvious it wasn't going to come off so I took a hack saw to the opposite end that doesn't connect to the Strut, and finished it off with a dremel tool. That part cost me $8 and probably should be replaced anyway.
I got 248,000 miles out of my struts, hope I get another 248,000 on this set. lol
be careful, keep your hands away when disconnecting, use a jack to lift the frame, then when you put the new strut on use a jack under the wheel to raise it to align the holes in the strut and also the stabilizer bar. This is a simple job, the only problem is rusted bolts. And get the complete strut and spring.
