I want to install fuel cut out switch and found relay but want to know what colour wires i can tap into to shut fuel pump off. And easiest location as want inside cabin 2009zr6 rav
Does your Australian RAV4 use an immobilizer key? It does if there is a Security light that flashes until you insert the key. If so, the easiest way would be to wire a switch to disable the immobilizer signal. That way the ignition and fuel pump would be disabled. It will crank but not start.
Its ok , i tapped under fuse to fuel and installed switch in cabin and works perfectly .thanks
