fuel gauge has just started to move up very slowly when filling up. could it be a problem with the fuel level sensor?
Mine has been doing that for a while and when the tank is completely full, the needle sits a bit below the full mark. I've been told that I should spray the sender in the fuel tank with carburettor/injector cleaner to remove any build up of varnish. As I'm planning to change the in-tank fuel filter this weekend, I'll be giving this a go as well.
THANKS ASLAN FOR YOUR REPLY, WILL TRY OUT THE CARBURETTOR/INJECTOR CLEANER,AND LIKE YOU I MIGHT AS WELL CHANGE THE IN-TANK FUEL FILTER. AGAIN, THANK-YOU FOR YOUR REPLY.
