Looking to keep the look as clean as possible. Was thinking about putting it in the engine bay with an outdoor rated extension cable into my glove box or something. Need to wire direct to battery probably with a relay for ignition switching it on/off. Anyone have any pics of some setups they've done?
I don't know what inverter you have but the engine bay is not a friendly location for electronics. Make sure to use a fuse if you tap power from the battery and remember to select a fuse size according to how thick your cables to the inverter are. If you put a relay pick one so that you will not exceed 80% of the rated max load of the relay, they might stick or develop problems otherwise.
