Hi there I have a 2008 Rav4 limited V6 with 236k miles. When I test drove the vehicle no problems. After driving home, 1 hour on the freeway, the vehicle started to make some noise I cannot find. First there is a slight grind at or just after startup that does not continue more than 1-2 seconds. I did replace the starter and solenoid as the Bendix gear did have some wear and tear on it but the noise stayed. Then I replaced the relay thinking it was hanging, no change. Next there is a while from something that increases with rpm. Not sure as I cannot get under the car while it's running. The HVAC fan whine I understand. Any ideas?
