41 - 54 of 54 Posts
Well I was able to fix my gas LE cause of the lose screw, but it still rattle from time to time as well as vibrate a bit on highway. My Hybrid LE however, the mirror are rock solid and don't even move on the highway. So there is def something wrong with people that have rattles or vibration on their mirror, since based on my experience, well they all do it. Hoping for you they can fix it perm.
Oddly, my mirror glass itself is rock solid at all speeds. Just makes the cheap sounding vibration when closing the door, and occasionally when hitting a bump the right way on the road.
Discussion Starter #42
Just shooting this out, have you though of removing the mirror and putting a small sound deadener between the mirror and the door? Like an improvised gasket? Perhaps it would dampen the vibration enough to not be noticeable?
Mine also sounds cheap when closing the door though. I am planning adding sound deadening this summer to this Rav4 as well.
Anyone know the trick to removing this black piece? On the driver door and trying to get in there to check out tight the mirror bolts are. I took the screw out but can’t seem to figure out the trick and trying not to break it. Thanks!
In the absence of screws or bolts securing it in place (look carefully)-- use your nylon trim tools to work it loose from the inevitable plastic tabs holding it in place. Amazon trim & panel removal tools: great investment for doing exactly what you're attempting, as here:
Amazon.com: GEHUAY Trim and Panel Removal Tools, 19Pcs Auto Upholstery Fastener Tools Clip Plier Set Fastener Remover for Automotive, Marine, and Aircraft: Garden & Outdoor
2020 Rav4 TRD Off Road, Fully Loaded, built in Canada.
Hi all, I have been tracking this issue for months now. I bought a 2020 Rav4 TRD Off Road, fully loaded, in January of 2020. My Rav4 has excessive mirror vibration/shake/rattle anytime I drive over the smallest bumps (the tar lines in the road, lane markers, small cracks, etc. etc) an when driving at speed if there is buffeting by the wind. Both the driver and passenger side mirror produce the same level of vibration/shake/rattle. I drive the car on a daily basis and find the vibration/shake/rattle so incredibly distracting that I cannot focus on driving, let alone "enjoy the driving experience".
I have taken in the car once to have the dealer look at it, and I got the whole "it is normal/like model comparison" explanation and no offer to help fix the issue.
Since then I have completely dismantled the driver’s side door and mirror (and will be posting pictures of the whole thing in the near future}. Unfortunately, everything that I have done has not helped, despite some other users stating that they had loose screws and tightening screws and nuts resolved the issue, it has not helped in my vehicle.
My initial analysis is that the mirror assembly and the mounting in the door are just a poor design that are not rigid enough.
Has anyone had any further progress on getting the issue resolved?
It's not poor design. It is "normal" design. Toyota upgraded this door mirror design from their previous door mirror designs to increase your safety by providing you an enhanced perspective of your surroundings. I'm more concerned about the vehicles that aren't operating normally and don't vibrate. If it rattles, that's just to remind you to use your vibrating mirror - much like an audible alert when a door isn't closed. There are days when I'll drive a whole 2 blocks and not even use my mirrors. This is dangerous. I wish I had vibrating mirrors to remind me to use them - for my own safety and the safety of others.. By 2022, Toyota is planning to launch all new models with this design as part of Toyota's Safety Sense.
Somewhere in this thread somebody talked about the (manual) folding mechanism being the vibration culprit. Try wedging something in there or slightly folding the side mirror and see if it makes a difference in vibration level. Then report back please. I’m waiting for a Rav4 Prime and I expect it has the same side mirror design.
For about 6 sentances I thought you were serious and I was very concerned.....
I have tried that, but only limited reduction in vibtration.
I hear that since the mirror can vibrate so much that it becomes unusable they will also be adding enhanced BSM that will send a shock through your seat.
I finally decided to open up my door panel in order to look at what could be causing my mirror to vibrate and though that while doing it, i might as well write a quick how to remove door panel. A quick spoiler, i found and fixed my vibrating mirror 
You will need a small flat head, a #2 Philips and a trim removing tool. Sorry for the pics, I didn't know how to directly attach them.
Step 1: Using your trim removing tool, pop-out the power window trim. Be gentle. Unclip the power connector afterward. View attachment 125071
Step 2: Using the same tool, remove the small trim around the door handle. Behind this you should find a screw that need’s to be removed with your Philips screw driver. View attachment 125073
Step 3: Now, you can remove the side rubber style fascia. To do so, there is a small insert where my finger is pointing where you can insert a flat head screwdriver. Gently pry it of. After make your way with a trim removing tool and gently pop-out the remaining holding clips. View attachment 125079
Step 4: There are 2 screws holding this panel and they are located where you pull the door to close it. They are into the circle opening. There is a final screw to the far right. (See picture) View attachment 125081
Step 5: Using your trim removing tool and starting on the bottom left of the door (there is an insert) slowly and gently start prying the door panel off. You need to be really gentle to not break the retaining clips. You should hear some obvious pop when one of those clips release. Once they are all released, remove the door panel upward.
Here is what the inside of our doors looks like. As you can see, there is no insulation at all, no anti vibration pad and we were wondering why the Rav4 felt noisy. I know I'll be installing some insulation on my own when it gets warmer outside. View attachment 125075
Now to my final issue, my mirror. When i started inspecting, i found 2/3 screws that are holding my mirror to have become lose. I also found a random screw on the door it self that was tighten 2/10 probably. After tighting these bolts. My vibration is now gone !!!! The screws where located behind that black housing and the random one was on the top of the panel. View attachment 125083 View attachment 125077
What I've learned from this is that my Rav was probably built on a Friday.
How do you get behind the "black housing"?
I want to do a big write up, but life is getting in the way. Here are some pics for you all. I have taken apart everything that support the mirror and put it back together and tightening it more than I should have and thread locking the questionable parts. I have even increased the spring tension on the folding mirror and I still have the vibration.
Note the vibration is significantly worse when the car has been sitting in the sun (aka stuff is getting hot and expanding).
My 2 cents as an engineer. The sheet metal brackets that the mirror mounts to are not rigid enough to prevent the whole mirror and brackets from flexing.
Comments are below each picture. I followed this video (
) to get to the below. I have taken the mirror completely off twice now with no issues.
153266
Door interior panel removed, all gaskets removed.
153274
The three mounting bolts that mount the mirror. Mine were tight the first time I took the door apart.
153275
The bolt that Sunken showed that was loose. Mine was tight.
153276
The bracket that the mirror mounts too.
153277
Another view. The bracket is a massive cantilever.
153278
Another view from the top.
153279
The mirror removed. The mounting screws thread into the plastic (glass filled nylon?) structure of the mirror. See next pics. Note, that these screws were not as tight as they could have been. I addressed that later.
153280
Another view. You have to remove the red tape to get the gasket off.
153281
The internals. I do not advise you to go this far, as the plastic fascia surrounding the mirror is very fragile. Somehow I managed not to break anything.
153282
Note the tab locations...and how to flimsy they are!
See next post......
Continued from above
153283
Note the 3 screws (Torx 25) where not very tight. I addressed that later.
153284
I skipped a few steps, but by taking off the plastic cover on the top of the mirror you have access to the spring that provides tension for the folding mechanism. In order to remove the washer holding it compressed, you need to be able to compress the spring about 1/4" or so then rotate the silver washer. I did this my make a custom 3D printed fixture of sorts combined with some long wood working clamps. Sorry I didn't get any pictures, it was not pretty, but it worked. If anyone is interested I can provide more pics and 3D files if they want.
153285
Mirror folding mechanism internals. The yellow stuff is grease. The 3 flat "pads" are where the mirror slides for the folding functions. I definitely think it could use more surface area.
153286
The other side of the sliding surfaces. Note, that when you rotate the mirror, it causes the whole mirror to "lift" allowing the little "castle" parts to not mesh together and then slide/rotate.
153287
When I put it back together I put a 2mm spacer to give more tension on the spring. I tried to go for 3mm, but it wouldnt fit. Once again a 3D printed spacer.
153288
Another view.
153289
I thread locked all the screws that I removed and tightened them back up. The 3 internal screws show several images above, and the 3 shown here.
Despite all of this my mirror vibrates anytime hit any bumps. As I mentioned before, it is significantly worse when it is hot.
A little Slo-Mo action for you when I close the door. Be patient, it is a little slow to start.
41 - 54 of 54 Posts
