I finally decided to open up my door panel in order to look at what could be causing my mirror to vibrate and though that while doing it, i might as well write a quick how to remove door panel. A quick spoiler, i found and fixed my vibrating mirror
You will need a small flat head, a #2 Philips and a trim removing tool. Sorry for the pics, I didn't know how to directly attach them.
Step 1: Using your trim removing tool, pop-out the power window trim. Be gentle. Unclip the power connector afterward.
Step 2: Using the same tool, remove the small trim around the door handle. Behind this you should find a screw that need’s to be removed with your Philips screw driver.
Step 3: Now, you can remove the side rubber style fascia. To do so, there is a small insert where my finger is pointing where you can insert a flat head screwdriver. Gently pry it of. After make your way with a trim removing tool and gently pop-out the remaining holding clips.
Step 4: There are 2 screws holding this panel and they are located where you pull the door to close it. They are into the circle opening. There is a final screw to the far right. (See picture)
Step 5: Using your trim removing tool and starting on the bottom left of the door (there is an insert) slowly and gently start prying the door panel off. You need to be really gentle to not break the retaining clips. You should hear some obvious pop when one of those clips release. Once they are all released, remove the door panel upward.
Here is what the inside of our doors looks like. As you can see, there is no insulation at all, no anti vibration pad and we were wondering why the Rav4 felt noisy. I know I'll be installing some insulation on my own when it gets warmer outside.
Now to my final issue, my mirror. When i started inspecting, i found 2/3 screws that are holding my mirror to have become lose. I also found a random screw on the door it self that was tighten 2/10 probably. After tighting these bolts. My vibration is now gone !!!! The screws where located behind that black housing and the random one was on the top of the panel.
What I've learned from this is that my Rav was probably built on a Friday.
