1 - 9 of 9 Posts
I have other cars and never has a rear suspension been this hard. Whenever it hits some ditches I feel a hard jolt instead of car sucking it up. Is it just me or these 15 models are like that? Any recommendations on rear shock replacements?
yess... mine like that too..
really ?
Pretty much that way since 2006, a BMW it is not.
BMW ??. I had a forester and a Honda Pilot in the past and none had such bad rear shock setup. It does not have to be a BMW to expect smooth ride.
Wonder what replacement options are available
I agree with you. I know of no replacement options as many here have sought a solution to no avail. I will say that tires can make a marked difference because we recently experienced it on our two RAVs.
I still have my 2013 Limited... Going over bumps and potholes will chip a tooth. Never owned a Toyota with suspension like this.
The rear suspension was significantly improved from the factory in 2016. There were a number of substantial changes like modified welding and structural points, but I wonder if they softened the shocks as well. It would be interesting to see if the rear shocks have different part numbers.
So I have to ask...did you all buy this car over the Internet and not take it for a test drive? I mean really...you all make it sound like you are driving a tank or something! Didn't you drive it around the block a few times before throwing down your hard earned cash?
Not claiming to be a victim at all. I test drove my Rav on a day that was under 30°
I figured the cold weather may have had something to do with the stiff ride.
My real mistake on this purchase was already owning 9 Toyotas before this one
and being mentally conditioned into confidence of the products.
I mean, at that point, you figure these guys know what they're doing.
In the case of the 2013 Rav4 suspension, NOPE.
I have a 2018 rav4 and when it goes over bumps and small hole it hits really hard as he'll i mean a loud bang like if the shocks were worn out it only has 16,000 miles
1 - 9 of 9 Posts
