Hello, so I wanted something to commute to downtown Seattle and perhaps take monthly short road trips in the area, already have a v8 4wd 4runner which is fun but seems excessive plus the v8 mpg is not great.
Stumbled on this forum, liked the 4.2 and few weeks later found a, 1 owner, local 2001...
Hello, first time post and new to the forum -
I have a 2003 RAV4 with 71,000 miles on it, I purchased a 2 years ago from a little old lady that rarely drove it. There are no issues, warning lights or problems with it. I have new Goodyear Assurance tires on it and the oil is changed regularly...
My problem is ... 2002 rav4 automatic 4wd that I financed 2 years ago...
Currently car is running poorly, replaced valve cover gasket (fixing vacuum leak) but throwing obd codes p0420 (catalyst efficiency bank 1) & p0430 (catalyst efficiency bank 2). I purchased an o2 sensor then realized I...
02 4wd with 117k miles. Started to get the dreaded grey/blue smoke at cold startup. Lasts for about 10 seconds and then goes away. Only happens at Cold startup in the mornings or whenever in the middle of the day when the car has been sitting for awhile. My research has told me that the most...
hi guys how its going
i was underneath the car to locate an oil leak some where
well I've found a second screw or a plug just above the oil pan which cant be a drain plug
or is it just a screw attaching a bracket or a mount to the block
correct me if I'm wrong
its a 2.0 L 1az fe engine
