Try here:
www.rav4world.com
Fogs
Before: After: First attempt to insert pictures in this forum -- by all means, let me know if I could have done it better! thoots
What I found that a good set of replacement bulbs were more than the OEM LED versions and since you have to access them the same way, the OEM's were the way I went. I am happy with the results.Looking to put something much brighter "off-road" than the OEM, checking out if anyone has shopped around and found some good options?
RAV-ON
The glare in the picture is amazing.I bought these plug-in-play LED replacement bulbs on Amazon for $16.50 and replaced them in under 10 minutes. The work and look great.
Alla Lighting H11 LED Fog Light Bulbs DRL 2800lm Xtreme Super Bright H11 LED Bulb 5730 33-SMD 12V LED H11 Bulb for LED H8 H16 H11 Fog Lights DRL - 6000K Xenon White https://www.amazon.com/dp/B07H6X6PM2/ref=cm_sw_r_cp_tai_x-lsDbWSBT3A3
Sent from my iPad using Tapatalk
Forgive the potential stupidity.I replaced mine with the OEM LED fog light assembly’s. I love the results!
Nice, can you provide the link where you purchased this set from?Purchased the same Amber LED fog lights. Replaced them a couple days ago View attachment 144757
You can replace just the bulbs for $16 in 10 minutesForgive the potential stupidity.
The LED element, or the entire Toyota assembly (Left, Right, and LED units) with LED's?
I guess what I'm getting at, if the vehicle has Halogen bulbs, you need to replace not only the 'bulb' units but the entire receptacle and 'bulb' unit?
PT41342191 x 2 LED
8122047010 x 1 (left) . . . ?
8122147010 x 1 (right) . . . ?
Have a link for the amber led lights, I'm looking for a set like these.Purchased the same Amber LED fog lights. Replaced them a couple days ago View attachment 144757
Purchased some LED bulbs off of Amazon and installed them yesterday. Super happy with the upgrade! Now to order LED bulbs for the interior.
Thank you!You can replace just the bulbs for $16 in 10 minutes
Replacing the stock halogen fog bulbs with LED for...
I replaced the stock halogen bulbs with LED bulbs for $16.49 in under 10 minutes. Alla Lighting H11 LED Fog Light Bulbs DRL 2800lm Xtreme Super Bright H11 LED Bulb 5730 33-SMD 12V LED H11 Bulb for LED H8 H16 H11 Fog Lights DRL - 6000K Xenon White...www.rav4world.com
