1 - 2 of 2 Posts
Ok got my Rav4 2003 about 4 months ago and not been able to direct where my heat goes at the moment it is stuck blowing all directions front window/feet/side blowers.
checked made sure cable was connected to the turner knob on dash and it was, what is wrong how do I fix thank you.
2016 Toyota RAV4 Hybrid XLE
Unfortunately it sounds like something you'll need to take to the mechanic... Likely not a do-it-yourself sort of fix. The mechanical system that actually adjusts the where the air flows inside the ductwork is clearly not functioning correctly and it's probably not an easy thing to get at since everything is electronically controlled these days. If the air is going everywhere, it's also possible that the control flap has gone AWOL or something... Wish you good luck on that one! Sorry it's not a simple fix!
1 - 2 of 2 Posts
