2013 XLE Drivers side heated mirror is pooched. 14V ok at the harness and no continuity across the terminals and about 50 ohms. Passenger side works fine.
Anyone have aftermarket manufacturer and/or part #'s ? Does the glass itself come with the plastic backing or do I have to try and rescue that from my existing mirror ? Googled this to death and good info is sparse.
TIA
Tedder
Parts list at the below link.
https://parts.toyota.com/a/Toyota__RAV4/62980170__6725525/MIRROR/662440-8701.html
What I thought was the complete mirror, may only be the inards. Make sure to study images carefully when using the below part number. When buying aftermarket, it looks like you get the entire mirror in search and probably will but when looking at OEM, it's hard to tell by the pictures what exactly is included.
Complete mirror replacement when looking at aftermarket # 8794042B50
Googling the above part number will provide numerous full aftermarket replacements.(Priced between $80-$120ish, OEM MSRP = $275) Looks like the same mirror was used 2013-2015.
Good luck!
Looks like part # 8796142D20 is what I need. I called a stealership and they quote $80 CAD.
