I'm about to install a trailer wiring kit on my '11 base and I found this plug which the harness instructions do not account for. Can anyone tell what it is for? Is on the left side (dr. Side).
Thx
Vehicle Vehicle door Automotive exterior Car Trunk
Sent from my SAMSUNG-SM-N910A using Tapatalk
That connector would go to the magnetic clutch on the rear differential IF you had 4WD, which you don't. The other end of that wire goes to a connector under the dash behind the glove box, and you could use it for your hitch wiring if you wanted to.
Thx a bunch!
