E
etop
·Guest
I was driving home from Charlotte NC today and the MAINT/REQUIRED indicator came on. I looked at the milage on the Odometer and it registered exactly 5000 miles. I read somewhere that to cancel this indicator, you hold in the (A) trip set for 6 seconds as soon as you turn the ignition on and it should go out. It did not seem to work when I first tried it. When I got home, I went back to the garage, pushed in the (A) trip set, than turned on the ignition to the position where all the indicators are on and after about 6 seconds the MAINT/Required indicator went out.
I am sure you all will experience this warning when you hit 5000 miles. As I said, at exactly 5000.0 miles it comes on. Anybody else have this happen?
