HI,
I have toyota rav4 All wheel drive with remote starting. My driver side powerlock is not working. When i lock door using remote. I can hear the doors are locking. but after 2 seconds its unlocking (I can hear the unlocking sound). Driver side lock is not locking. but all other doors are locked. I went to workshop. They tried with new actuator. But still not working. Now i am locking the car with key manually. I have tried to reset program using the procedures shown below.
Instructions for the 2004 RAV4
1. Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter).
2. Perform these steps within 5 seconds
1. Insert the key into the ignition (don’t turn it) Pull key out
2. Insert the key into the ignition (don’t turn it) Pull key out
3. Perform these steps within 40 seconds
1. Close, then open the drivers door.
2. Close, then open the drivers door.
3. Insert the key into the ignition (don’t turn it) and pull it out.
4. Perform these steps within 40 seconds
3. Insert the key into the ignition and leave in the ignition.
4. Close the drivers door
Turn the ignition to ON (as far as you can go without cranking the engine), then back to off .
5. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds
1. Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
2. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
7. Open drivers door
So could anyone help me to fix this issue.
