Hi all - I read through almost all of the install threads on the RAV4 and I am not 100% certain on a couple of things. What's the most "fool-proof" way to tap into the sunroof motor wires? What gauge are these wires? I'm hearing T-Tap, Scotchlok, etc. What should I be looking for? Gauge and type?
And where I should look to connect the ground wire? Am I supposed to tap into the black/white wire or just bolt it in somewhere?
I assume I tap into the same wires as this guide from a 2013 model
This is how mine looks on a 2016 model. The wires are similar but I wanted to double check.
Here are the 3 wires that are coming from the mirror.
Thank you in advance for your help!
