Hello everybody, long time lurker and first time thread maker here, hoping to find a resolution to my issue (if it is).
While installing a Front Runner Slimline II roof rack the other day I was tightening one of the bolts and felt the gut-wrenching yield when it stops getting tight and just spins. The bolt in question is circled in the picture below. I ended up using a steel epoxy to coat the threads on the bolt and tightening it down as much as it would go. I waited a day and then finished the installation of the rack.
The bolt was still not as tight as the other ones so my major concern is that I've now created an intrusion point for water to leak into the vehicle. Is that the case or does this bolt hole only open up to the waterproof canal that runs underneath the raised plastic rail?
As for the structural integrity issues this may cause for the rack itself, the loose bolt is only 1 out of 8 bolts that hold the feet so once the rack was on it felt very secure and did not wobble or move by the stripped bolt. So hopefully this is not an issue.
Anyway, thank you for any information that can be provided.
