Help my VSC and ABS light come on when I hit the brakes hard. What do I need to do because I can't use my cruise control. I investigated and it looks like maybe I need to check my EGR valve. If so where is it at? How do I check it?
If the EGR valve is the problem your check engine light would be on. The EGR has nothing to do with your braking hard. First check your brake fluid level in the reservoir. Second, read this thread:
