Hello,
I have a 2005 Rav4 that the airbag light went on. I have Techstream, so I read the Airbag Codes. It read B1615 Front sensor (LH) So I ordered a new one. After replacing the passenger side Sensor with the new one, the code was still there. So thinking I had the wrong side I installed the passenger side one on the Drivers side. The same code was still there. While changing the sensors I had the battery unhooked of course. I don't use Techstream alot, I'm wondering if after changing the sensor if there was something I was supposed to do in Techstream to reset the system or if it should have cleared by itself after replacing the sensor?
Thank you
I'd take it to the dealer as I believe the SRS is warrantied for the life of vehicle.
