Hey guys, I am hoping someone can tell me how to fix my problem. I am replacing a busted quarter window on driver side passenger door. I took the panel off, disconnected the regulator and removed large glass, then removed separator and put in new glass (in old gasket/seal). The problem is I can't seem to get the large window back in. I was able to get it back inside the door but can't get the gasket in place with the separator in. If it put the gasket in the separator before putting it back in, then I can't even get the window into the door and if I put the separator in without the gasket, then I can't get the gasket in because the window is sticking up 2-3 inches-won't go any lower. I found several links online that gave instructions on how to get to this point but none address this issue. I would so appreciate you help-I am pulling my hair out!:mad:
