Install LED light car wont turn on IDK what happen battery is good push the button car wont turn
Esco · Registered Joined Apr 17, 2016 · 16 Posts Discussion Starter • #1 • Apr 30, 2016 Install LED light car wont turn on IDK what happen battery is good push the button car wont turn
S Steka · Registered Joined Jul 11, 2015 · 28 Posts #2 • Apr 30, 2016 Have you already tried to just rotate them because of the polarity? Usually that's first problem with LEDs,I had it too,simply rotate them for 180°
vetterin · Registered Joined Feb 28, 2016 · 72 Posts #3 • May 1, 2016 Check your fuses. Sounds like you shorted one out.
Esco · Registered Joined Apr 17, 2016 · 16 Posts Discussion Starter • #4 • May 1, 2016 The car won't turn on no brake likes changed the brake light switch still no lights at all check the fuses there all good just no brake lights
Esco · Registered Joined Apr 17, 2016 · 16 Posts Discussion Starter • #5 • May 1, 2016 Fixed it blew 3 fuses never seen a car that if a light fuse blows the car wont start all LED are on but 7443 and 7440 those are the ****ers that took me out.
Esco · Registered Joined Apr 17, 2016 · 16 Posts Discussion Starter • #6 • May 1, 2016 you can close this thread
