My rav4 has been off the road for a while but I keep it dry stored. noticed last year when I took it home from mot the idle was at 1200rpm when warm but I did not put it on the road last winter so back in garage. This year same thing took it out, its runs at around 800rpm when cold and 1200 rpm when hot which should be the other way round. The emmissions were higher too as it just scraped through the mot with a bit of help from the tester:wink.
I'm thinking temperature sensor but I don't want to start throwing parts at it as I'm not sure what will cure it, so any help much appreciated. Rav also seems to be more thirsty than usual:crying.
regards kev
Sorry forgot to add its the 3s-fe engine iirc in case you need that info
regards kev
