Wash off crc . It’s 1 hour job
Mineral spirits (paint thinner) should work well......Wash off crc . It’s 1 hour job
CRC QD Electronic cleaner. Safe on plastics and rubber seals, meant for this kind of cleaning.Mineral spirits (paint thinner) should work well......
It's not a homocide crime scene, needs swabbing for trace DNA. If it looks as expected - nothing but environmental corrosion, I'd take my chances and be well prepared to have a very loud disagreement LOL. If Toyota were to deny warranty, for ANY reason about ANYTHING, they have lawyers on retainer and you, not so much.I'm certain they'll still swab it for chemical analysis and note the microscopic contamination. Nooks and crannies, it'll never be 100% sterile.
In this case just take bag of ice salt put it in the bucket with water and soak cable connector for a day - it will be exactly like after couple Canadian winters.I'm certain they'll still swab it for chemical analysis and note the microscopic contamination. Nooks and crannies, it'll never be 100% sterile.
but let's not exaggerate ... they don't do chemical analyzes on the cable !!!I'm certain they'll still swab it for chemical analysis and note the microscopic contamination. Nooks and crannies, it'll never be 100% sterile.
LOL , I wonder if some people think if they put wax on the body of the car , Toyota may not cover rust .but let's not exaggerate ... they don't do chemical analyzes on the cable !!!
if one has sprayed some product like spray CRC, they don't notice it !!! they don't let the CIA intervene!
First time I've done this work, but in general I've done most of the maintenance for the cars I've owned by myself. Re: the photos, I'm a professional photographer and used to freelance for the Ottawa Citizen newspaper. City Hall news mainly, not Automotive Sectiongarthg
Is this the first time you have done this work, or do you clean up the connector seal every winter? Great pics, by the way.
Here are some pictures of the HV connector, under my brand new 2023 MY Highlander Hybrid. There is no plastic panel/skid pad. under this connector.
Seems like a good thick application of dielectric silicone grease on the gasket and in between the connectors would be certain to stop water ingress.Highlander cable looks exactly the same...
Now $1M question : Why I should not apply gasket maker to seal the area where the connector mates to the wiring harness ?
It will prevent any moisture to get into connector area. Gasket maker applies to the connector - from bottom of black rubber seal and all metal area below (around seal, bolts area and e.g. )
This is a 2023 Highlander Hybrid, not a RAV4 Hybrid.Quite interesting 🤔
Can you confirm this is the standard now...wondering if they might have felt the tray
might be capturing the moisture and road spray that it was designed to block...
thanks...🙂
It appears they added a plastic panel below the connector sometime in the '21 model run. My July '21 build has one. One of the videos from the Car Car Nut earlier shows this.Quite interesting 🤔
thanks...🙂
My July 2022 manufactured RAV4 Prime has this panel as the Car Care Nut (Ahmed) showed it to me when my car was up on the lift along with the infamous connector on the HV cable. Now I'm wondering if the 23 MY RAV4 Prime has the panel removed. Anybody with a 23 MY RAV4 Hybrid or Prime know?It appears they added a plastic panel below the connector sometime in the '21 model run. My July '21 build has one. One of the videos from the Car Car Nut earlier shows this.
