Coming back from my Thanksgiving vacation I had to take a detour through a residential area I was unfamiliar with. While driving about 45 mph I came across a boulevard that had a big dip and caused my front end to scrape the ground. I checked underneath the next day and can't see any signs of damage. My alignment doesn't seems to be affected (when I let go of steering wheel it stays straight). Anyone else recommend I check anything based on the description of what happened? Thanks
I did that with my 2015 XLE. Ran through a yellow light and didn't see the road dipped until I was in the intersection. Definitely bottomed out the front end. No damage, but I would just inspect the shocks for any leaking fluid and check the springs.
Sent from my XT1585 using Tapatalk
The lowest point of the car in the front is the exhaust where it connects to the downpipe. Have a look to make sure you didn't do any damage to it.
