1 - 1 of 1 Posts
The driver door window glass has started to lean out as it goes up or down.....now it won't close all the way at the top because it does not line up with the door.
Where do I look first to adjust this back into the proper alignment?
Oh, this started after the door latch froze. I was unable to get the door open in spite of LOTS of hard work. Ultimately the Nissan dealer removed the window glass and airchiseled the latch mechanism apart through the window channel. Putting in the new latch was simple then. I suspect something was not tightened when they replaced the window glass.
1 - 1 of 1 Posts
