R
I removed the screw for the tun signal and the upper housing comes out for that, but the fog light housing under that seems like it's stuck. I don't see any screws or anything? do i have to get to it from under the bumper or do I just pull hard and pray?
Any help would be appreciated.
thanks!
R
Discussion Starter #2
i found it. you have to use a screw drive and push one side over and pull hard. there is a ball joint in the rear holding it in place.
J
Thanks Ryan, you save me a lot of time and trouble! I just came across this issue and found your advice most helpful :)
I had the same problem. But here's the solution:
Right side light as you're looking at your car (driver side):
1) Rmove the top section
2) Using your hands, push the fog light casing to the right with all your might.
3) The left side should release from it's latch and you should be able to slide it out by pivoting on the right side.
NOTE: The right side (outer side) of the casing is held on much tighter than the left side (inner side). There is no way to remove this right side part w/o first removing the left. Sound confusing, but you'll know what I mean when you try it.
Email me if you have problems. If it's not budging, don't force it.
