Update: OK. I was wrong. D Shifts from 1 to 6.
It looks like the position D will shift from 1 to 4.
How often in real everyday drive do you shift to 5th and 6th gears?
What is the best practice for you or recommended by Toyota?
Drive shifts to all 6 gears. You cannot even manually shift in drive (to 5th and 6th as you suggest), only manual mode. It goes to 4th when you shift into manual, but that doesn't mean that is where drive was at the time.
You dont worry about it, unless you want to count shifts. It will generally land in 6th somewhere in the 40s and downshift when it needs to or as soon as you even touch the gas.
