For our 2016 Rav4, there was an instance where my wife left keys in the ignition ON position and drained the battery. The car was jumped started, the AWD and VSC lights remained ON.
Basic code readers from Autozone or O'Reilly's are not able to read the code. The Rav4 has several computers or "modules" for different functions of the car. Very basic code readers only read the engine and emission module. A more advanced code reader is required to read the ABS/AWD/VSC module. I purchased an Autel MK808BT which has far more capabilities than required for this job. I like this scanner because it has bi-directional features - it can bleed the ABS module, do programming for the TPS sensors, plus other functions. The important thing is to find a scanner that can read the ABS/AWD/VSC module. The key indication the steering angle sensor is bad is a U0126 Steering Angle Sensor Lost Communication.
I purchased a replacement steering angle sensor from ebay for about $90. Part number 89245-12040.
Attached are step-by-step instructions on how to do the replacement. It was pretty easy to do. Just take your time and don't pry too hard on any of the connections. Other posts mentioned a steering angle sensor replacement at the dealer costs more than $1000. Most backyard mechanics should be able to do this repair.
By the nature of the instructions, you'll also see how to remove the steering wheel air bag and the clock spring.
