Hi everyone,
I am posting this article for anyone like myself who wants to have another Keyless Remote and has not done so before.
My Rav came with 3 keys and 2 remotes. (I think this is a hint from Toyota to buy something) :roll:
So today my 3rd used remote came from Ebay at a $10 total cost.
Here is what you need to do if you would like to do the same.
1. Get the full ID numbers from the back of the Remote.
Mine where: FCC ID:HYQ12BAN
CANADA: 15511021295
RSS -210
DENSO
2. Buy the same on Ebay
Next is the programming. If your neighbors see you do the next step, well they might think you lost your mind. :?
1. Start with the following conditions: You are in the driver’s seat.
a. Key is out of the ignition
b. Driver door is open (all other doors closed)
c. Driver door is unlocked (other doors don't matter)
2. Insert and remove the key from the ignition twice within 5 seconds.
3. Close and open the driver’s door twice within 40 seconds.
4. Insert the key into the ignition and remove it.
5. Close and open the driver’s door twice within 40 seconds.
6. Insert the key into the ignition.
7. Close the door
8. Turn the key in the ignition on and then off.
9. Remove the key from the ignition.
10. Press both transmitter lock and unlock buttons SIMULTANEOUSLY for duration of from 1 to 1.5 seconds.
11. Within 3 seconds, press the transmitter lock button for more than 1 second and release.
12. If the transmitter has been successfully programmed, the power locks will automatically cycle once. If they cycle twice, the remote has not been accepted.
d. If multiple remotes are to be programmed, repeat steps A-C.
13. Open the driver's door.
The lock button worked right away.
Where-as the open did not work until I exited the car and closed it again.
I missed one step the first time. The second i just did the all the steps as fast as i could and it worked.
I will never use a key to open my Rav again! :wink:
Cheers, Walt
CANADA: 15511021295
RSS -210
DENSO
7. Close the door
Cheers, Walt
