Issue #1
What tool do I need to get this drain bolt off? I have the necessary 24mm socket, but I cannot get my wrench in there due to interference. Here you can see the socket on the bolt, with a very minimal amount of clearance to the pipe. The wet stuff is the case fluid that dripped out when I took the filler bolt off. Have a look:
Issue #2
When peaking around down there I see an empty threaded hole behind (towards rear) and above (towards top of car) the oil pan. This is near the passenger front wheel. Am I missing a piece of hardware?
Issue #2
