1 - 2 of 2 Posts
S
Can someone help me by saying in detail how i can remove my radio from my 2001 RAV4 . I have screwed the screws loose once but the grey alu plastic thing wouldn't come off are there clipps attached or what? can someone pleez help me with some info or pictures how i can remove the radio
Thanx Gerry
The plastic surround is held in by clips in addition to the four screws. Using a putty knife or another flat tool, pry the edges of the surround a little bit at a time under the whole thing comes loose. Once you get that off, use a 10mm socket or nut driver to remove the 4 bolts holding in the radio brackets. You have to be careful that you don't drop the bolts down into the hole because they are hard to get out.
1 - 2 of 2 Posts
