Has anyone tried to remove a broken stud from a 30mm spacer? Any advice would be appreciated. Both left and right rear stud were broken some time ago and since I'm on vacation I think its time to tackle this chore.
As you can see I am using McGard Lug Nuts all around. But these two have had it. BTW, the McGard part # are as follow M12X1.5 64002. They are better then stock. But look like some minimum wage idiot didn't torque them down and I'm paying the consequences. What a coincidence that it happen one on each side.
Studs are a press fit, with splined ends. So a BFH is required, big f* hammer.
Forgot to say, the press in from the rear, so you have to knock the threaded part. In your case you may need a punch as your threaded part is broken off.
3mm Spacer on with stock studs
Hi,
I am trying to put some winter tires on 2012 Sienna 17" alloy rims. they have the same wheels specs as 2012 Rav4 that I own. The wheels fit perfect on the rear wheels but on the front, the calipers are scratching the inside of the wheel. I am thinking about using a 3mm spacer to give it some room. I am wondering if I could the stock studs or do I need or replace them with longer ones. Could someone help me here?
thanks in advance.
Hi,
thanks in advance.
Many wheel spacers have their own studs, that's how my 1" spacers work.
Link https://www.amazon.com/gp/product/B00A7I380O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
