Wet carpet and passenger's floor? Here's how to simply unclog the drain tube. Video is of 2020 Camry and the 5th gen RAV is the same.
same.
To tell you the truth, not sure what causes clogging. The video eluded to spiders but I have never had a clogged drain.Is there any way to prevent this from happening? Does running the A/C with outside fresh air instead of recirculate help? Any truth to spraying Lysol in the intake vents from time to time? Would it help to blow compressed air from the cabin side tube under the rug?
CarCareNut on YouTube has said to turn your A/C to fresh air intake from recirculate every day when you are about a mile from home to help prevent clogging and foul odors. I just leave mine on fresh air unless it's very hot or cold.Is there any way to prevent this from happening? Does running the A/C with outside fresh air instead of recirculate help?
Please note: you have to use an air compressor to do it like in the video -- air in a can (keyboard cleaner) is not strong enough.Blowing air from the bottom of the car like in the video is the quickest and easiest way. If it for whatever reason it didn't work you could disconnect the hose to the floor tube and do it from the top or even run a wire or coat hanger down it. However that won't clean the upper hose going under the dash to the A/C. You could I suppose blow air up the disconnected upper hose from inside the car and catch any liquid that comes out in a container.Would it help to blow compressed air from the cabin side tube under the rug?
Wouldn't hurt. Would smell good for a short time. Some people swear this is a good method on YouTube. I don't think it would prevent clogs which are basically algae from stagnant water-- not spiders as the guy says in the video. Using fresh air instead of recirculate dries the innards of the entire A/C system out.Any truth to spraying Lysol in the intake vents from time to time?
There is a factory T-SB on this issue because there was debris in the drain tube from the factory on some vehicles. The solution in the T-SB applies no matter the source of the debris: https://static.nhtsa.gov/odi/tsbs/2022/MC-10209001-9999.pdfWet carpet and passenger's floor? Here's how to simply unclog the drain tube. Video is of 2020 Camry and the 5th gen RAV is the same.same.
