Hey all, I'm having the "whom, whom" humming sound coming from my front drivers side. I'm thinking it is the Bearing Hub Assembly. I've recorded the sound and placed it on youtube. Can someone listen in and tell me if that is the typical humming sound you'd here? https://youtu.be/NqVumS8ft54
Things I've done so far:
Rotate the tires (Still comes from front drivers side)
Jacked it up to see if there is play. (there is play when grabbing the 3 and 9 o'clock and push/pull left to right; however, there was the same amount of play on the passenger side as well. there isn't play when grabbing the 12 and 6 o'clock and push/pulling)
Visually inspected for anything rubbing against the rotors (clear)
I'd take it to a shop but I'm in between employment right now and would like to stay away from the $750 rip off the dealer is trying to charge.
Please help. I'd like to get this resolved asap.
Thanks!
Thanks!
